Wierd buzzing noise behind dash...
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
There is this wierd buzzing noise coming from behind my dash and i don't know what it is. It only buzzes when the engine is running (not even when the key is turned forward). I can't really explain the buzz, but it's not the same sound as when you leave the key in the ingnition and the doors are open. Does anyone know anything that can buzz that is underneath the dash?
Thanks.
Thanks.
i would say check bottom of windshield all across for loose sealer, air could be making the VIN plate flap, i have had this happen on an 84 before, was a very odd wierd metal flapping ticking noise, but would quit at around 10mph and under usually, never happended at full stop.
hmm
hmm
Car: Camaro
Engine: 350 SBC
i found out what it is. It's this green box shaped thing that is plugged in right next to my turn signal flasher (silver circle). Does anyone know what it is? It doesn't seem to effect anything when it is unplugged.
choke relay, i just found all about this item yesterday, i have a few good used ones i have saved from past cut up vehicles ive scrapped, never knew what relay was for til yesterday, if its green and just like the white horn relay then its for choke !
good luck
good luck
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
yea... i think i hhave the same prob... its a low buzzing noise that only is there when the engine is running... but the thing is ... it isnt constant... it goes up and down in volume and sometimes off.... same thing ur talkin about???
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
I once had this problem in my car with the choke relay buzzing in the way you describe. The cause was my alternator dying. I had it reconditioned and then the buzzing stopped.
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
may be the speedo or some other guage.... i figured out that the sound was coming from the non working speedo or tach in my car
sjorgens
10-01-2015 07:54 PM
