Heat Guage
Heat Guage
I was wondering how to go about fixing my heat guage. The needle points straight down and I dont know where to start. Any tips or ideas?
temp gauge you mean?
take off the cover and move the needle-- make sure it's not stuck
sometimes when starting the car the needle will PEG either up or down and get STUCK
this happend constantly with my 87... if that's not it, make sure the sender's wire is connected, it's on the driver side part of the engine, and sort of near the bottom. I think it should be a GREEN wire.
If that's not it, you may need a new sender, i think.
this is a old post i no but i just got one quick question with needles being stuck. my needle it is stuck in one spot in the middle but on the other side> if i hit the plastic i can see it move a bit could it still be stuck if it moves a bit? i just replaced my sending unit today so thats fine.
thanks
thanks
