85 Berlinetta digital dash connector pinout?
I'm having problems with my -85 berlinetta digital dash. Most of time speedometer and tachometer are blinking, but they donīt blink simultaneously, so I donīt belive it is power problem. Also sometimes I can see tacho in speedometer panel: when I press pedal and rpm rises, new segments lit in speedometer
Anyway, I'm trying to find faulty part in dash circuits (I believe faulty part is there) and it would be great help to know dash connector pinout. Connector is with two rows, 16 pins at each row, rows labeled "C" and "D". Does anyone know pinout for that connector?
P.S.
Your Dash cluster is supposed to "blink" under certain conditions,....... Like:
Over 85 MPH the speedometer will blink
Over a certain RPM to indicate you are over the Engine's "yellow" line RPM limit. ( The Blinking starts at 4400 RPM in a V8 and somewhere around 5200 for the V6 Berlinetta Clusters. )
Wow! Thanks for fast reply, this helps me a lot. BTW, do you know about Berlinetta electrical wiring CD that Mike Myrick is selling, does it contain circuit of digital dashboard?
Also I'm trying to fix my Berlinetta radio/cassette console, where cassette side seems to be dead. Does anyone know pin-out of console? There's one connector with 8 pins, labelled from "A" to "H", in connector reads "P.E.D com-pack II". And thereīs also another connector with 2 wires: orange and brown.
1984, 84, 85, belinetta, berlinetta, camaro, cd, dash, diagnosis, diagram, digital, electrical, electtronic, problems, radio, speedometer, speedometers, wiring
