Help me decipher this code....please!
Bought a Actron scanner today, the $24.99 special. The SES blinks this: flash, flash, flash, pause...........flash,flash,flash,flash. The book really doesn't say what this is. Take a flash off the first series and it becomes a 24. With that extra flash, does that make it a 25?
Thanks,
Brandon
Thanks,
Brandon
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
code 34 is probably what it is.
Thanks! I highly doubt that problem really exists. The fuel pump won't prime nor will the engine even crank. Just went out there and disconnected the ecm. Did notice some teeth missing in both the connectors. Are there supposed to be?
Brandon
Brandon
MrPink
04-29-2012 10:27 AM
