B&M megashifter wiring?
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Hey guys, i got a problem you might be able to help me with. My reverse lights go on in reverse and 3rd gear , what would cause this? my connections are correct according to the supplied schematic. My guess would be maybe the switch itself? Anyone ver have this happen? any ideas on a fix? thanks
Car: 1989 Chevrolet Camaro IROC-Z
i had the same problem too... my reverse lights would stay on till a went up and down a few gears... then they would go off... i ended up just switching the reverse light wires and then it worked like normal... but i didn't use the relay either, just the switches
Car: 86 iroc
Engine: 355 TPI
Try adjusting the reverse light switch just lossen the switch & adjust it. That should solve the problem I think I had to adjust mine also. If you do a search also you will find ALOT of stuff on the Megashifter.
Glowsock
01-09-2017 04:06 PM
