Msc Questions, Vats, buzzers, and wiring
I am still working on an 86 Iroc with an 89 Bird harness. Getting alot figured out but got a couple of things I haven't figured out. the 89 has Vats and my Camaro didn't. The car starts and runs but I don't think the Vats system has been defeated. When I put the Fuse into the Courtesy lights the horn starts going off. I also have a fuse taken out in a seperate connector in the console thats also connected to the courtesy lights. I am not very familiar with the Vats system so this one has got me stumped. If the car will start then why does the horn go off when I install the fuse.
Another problem that I have is the car has a warning buzzer that I do not know what its a warning for. Its no the headlight and seatbelt warning, that is a dinger. This is a buzzer. Never had this new a vehicle before so the buzzer is a new one on me! Got lots of other things but thats where I am stumped right now.
THANKS
THANKS
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Re: Msc Questions, Vats, buzzers, and wiring
THANKS
THANKS
That was a quick reply!
Not convinced the Vats is bypassed however. The guy I got it from wasn't the best at wiring but it could be. I tried looking for the 2 yellow wires to defeat it myself but without the firebird key I can't do it anyway!
I will have to check on the horn, I know that at the moment it doesn't work from the wheel so I suppose it could have a bad connection.
As for the buzzer I would like to know what it is before I disconnect it!
THANKS
THANKS
THANKS
THANKS
I can tell you what that buzzer is
it's annoying. hehe...just my opinion
Could the buzzer be the keys left in the ignition with the door open buzzer?
Well the I will consider Vats defeated! Like I said I am not all that familiar with it. Hate new cars! To much bloody wiring Had an 85 Vette last winter that I guess had Vats but I didn't have it long and I didn't play with anything I didn't have to, to nice a car! It does have a stage one chip from Jet in the Ecm so maybe thats how? Guess I won't worry about it!
I will agree that the buzzer is an annoyance! Hate the things, yet another reason I don't like new cars. Most likely I will pull it along with the headlight dinger but I need to figure out what it is cause I gotta hook some stuff up that when I do it buzzes! I suppose it could be for the keys, the door switches aren't hooked up yet but I thought that was dinger anyway?
Thanks for your help, the vats being gone takes a load off!
hehe jk.
Thanks for your help, the vats being gone takes a load off! [/B]
