Installing an electric fan
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Ok I'm sure this question has been asked before but I haven't been able to find any replies that help me
Anyways; I just swapped out the MPFI 2.8l 6 in my 87 camaro for a non CC 305 out of an 85 berlie. I ditched the standard "belt driven" fan from the 305 in favor of my original electric fan, I now have the fan wired to a switch to turn it on/off, but i sometimes forget to turn it off. How do I wire the fan so it will come on & off at the right temp? I still have the remains of the V6 harness including the relays.
TIA,
Don
Black 87 2.8l Camaro
Soon to be 305/5.0
http://photos.yahoo.com/bc/z2point8l?d&.flabel=fld1&.src=ph
Aka Z2point8
TIA,
Don
Soon to be 305/5.0
Aka Z2point8
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
To have the fan turn off with the ignition, the +12 wire to the relay that switches it on needs to be on a circuit that switches w/the ignition. Also, instead of having the ECM as a ground since you don't have one, you could screw a JET fan switch into the block which turns on at 200° & off at 185. You could leave your switch inline with the temp. controlled switch to have a manual ground just in case something went wrong.
Also, I wouldn't worry about the 20 amp fuse off the battey if you still have the wires comming off the fusible link.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"I don't know the key to success, but the key to failure is to try to please everyone."
[This message has been edited by deadbird (edited December 10, 2001).]
86IROC112
08-17-2015 02:00 PM
