Why aren't my turn signals flashing anymore??
when i signal left or right they stay on solid front and back. my 4 ways flash, but the turn signals don't. hope you guys can help me out. thank you.
shawn
shawn
Check all your turn signal bulbs. If a bulb goes out the flasher on that side will not flash. Light in ****pit should come on solid on the affected side. Otherwise, it is the relay.
um, lets see. i kinda figured it was the flasher, but i wasn't sure because the 4 ways still flashed. second, i don't know where the flasher is. is it one of those silver canisters under the dash? and if so, which one.
Car: 1987 Pontiac Trans Am GTA
Transmission: WorldClass T5
Axle/Gears: 3.70
Sorry... don't know where the flasher is, but...
My 87 GTA had the same problem and I found that it was a short in the right front turn signal. Just in case you replace the flasher and it still does not work...
James
1987 Pontiac Trans Am GTA - 305 TPI - 700R4
James
Car: See ID
Engine: See ID
Transmission: M39
The flasher unit is found under the dash, on the topside of the fuse box (drops down by pressing in on the tabs on each side). The flasher for signals is seperate from the hazards. I recommend you purchase the electronic one since most Camaro drivers tend to make quick lane changes and the thermal flasher units take a moment to heat up and cause the light to flash. Not that I encourage rapid lane changes...<G>
Hope this helps.
Hope this helps.
<font face="Verdana, Arial" size="2">Originally posted by camaro 22:
um, lets see. i kinda figured it was the flasher, but i wasn't sure because the 4 ways still flashed. second, i don't know where the flasher is. is it one of those silver canisters under the dash? and if so, which one.</font>
Fronzizzle
03-18-2019 08:29 PM
