Digital cluster swap
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Will a digital cluster swap straight into my 89 bird? Since mine is electronic anyway should i just be able to replace it with my one, or is the dash behind the cluster different?
why are you wanting to do this??? digital speedometers lag and none of them are really known for being reliable. i've got the package in my '84, and am praying that they don't go out, even though that means that i get to put in all new auto meters.
'84 Berlinetta, LG4, 700R-4, starwars interior, no major mods yet
Engine: LS1 / LS3
Its a cool looking gizmo! I have always liked them, i doubt i will actually do it, i was just curious.
Summit racing has digital dashes for 82-92 camaros. For like $350, they hook right up to your wires. Suppose to be an easy swap. Thinking of doing it myself. I wouldn't use a used one.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
Car: Take
Engine: Your
Transmission: Pick
Its an electrical nightmare. The dash plugs are completely different, and there would be alot of custom wiring. And if it has the Driver Information Center, forget about that working at all. I am very good at wiring stuff up, and once I took a look at what was all involved, and re-sold my digital dash.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Engine: LS1 / LS3
Well GMTech, if you gave up on it then i am not even going to bother!! It was just one of those ideas that i had been kicking around.
Thanks for all the input guys.
hi there,
converting the digital dash was no problems, well for me it was not. i had the whole thing working in less than 3 hours. even the d.i.c. (drivers information center) it was in a 87 gta. my 88 gta has the facotry digital dash. everything on the dash and the information center worked just fine. just some re-wiring. the actual dash itself is the same as the digital dash. the harness are differant. theres a place for the digital dash harness. theres a total of 3 of them. 2 for the cluster and one for the d.i.c. all you need is both wiring diagrams for the analog and digtial dash. its just a matter of swapping the plugs over and running a few wires and adding a few sensors. its not that hard if you do wiring. you have to ask your self if you want to do this. the look is real cool and theres alot of nice features. i have done 2 of these conversions. if you want the wiring diagrams just let me know and i will send them to you.i wrote a few articles on this on the gtasourcepage. alot of people say you have to convert the a/c controls as well. but you dont. hope this helps you.
Kevin
Kevin
1 Post
Car: 92 Formula
Transmission: A4
Anyone got any pics of the digital dash?
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
92 Rs 3.1/T-5
AIM : Theonekiztope
ICQ: 8787542
Pilotrick50
09-02-2015 12:48 PM
1989, analog, berlinetta, catalina, center, converting, corvette, dic, digital, drivers, info, information, ls1, pontiac, swap
