How EZ Is It To Change The Gauge Lights?
Hi Board. I'm considering purchasing the MacEwen white face gauges and installing his Xenon bulbs. Do the bulbs just insert into a socket or is there soldering involved. They would be going into an 88 IROC. Any help would be appreciated.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1986 IROC-Z
Welcome to the board! On my '86 IROC, you just take out the eight (I think) screws in the dash panel, then there are a few more hex-head screws underneath that. Once you get the layers off, you'll see the bulbs... they just push right in. You might have a hard time getting them out of the deep holes they're in. I used a piece of rubber tubing, but an actual bulb puller might work better.
1986 Camaro IROC-Z
Code 23 Paint ("IROC Blue")
305 TPI w/ Auto Tranny
Grant GT Steering Wheel
New A/C Motor!
View my website, a work-in-progress
1986 Camaro IROC-Z
New A/C Motor!
Changing the bulbs is MUCH easier with the cluster out of the car. I changed them with it in the car and I broke a couple in the socket. Removing the gauge cluster only takes 10 minutes and it also makes the white overlay install a LOT easier when you've got the gauges on a work bench instead of in the dash. Anyway, once the whole cluster is out, the sockets simply turn 1/2 turn and come right out from the back.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
![](http://iroc.fbody.com/banner.jpg)
The IROC Homepage
Ghettobird52
12-29-2023 08:23 AM
