Will dash cluster from a 90 Camaro fit in a 89?
Once again I am not sure where to post. My question is twofold. The first is will it fit? The second is because its electronic will it connect to a 4L60 that came from a 93 Z28? I am in the middle of a motor swap and want to install the motor and tranny as close to factory orginal as possible., ie I want the electronic speedo gauge.
Thanks in advance for your help
m-t
m-t
m-t, the you can do the swap, but you have to do the ENTIRE dash, not just the gauge cluster, since the 90 IROC is different from the 85-89's.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Could your expand on entire dash? Will the entire dash fit? Has anyone done this? All I want is an electronic speedo that will connect to my 1993 engine/tranny combo.
Ron
Ron
Yes, the entire dash will fit. What I mean by the entire dash is the ENTIRE thing. The big entire piece that sits in front of the driver and passenger. You have to do this, cuz as you may already know, the gauge cluster is entirely different.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Your 89 should be mechanical speedo, and its a simple swap to put a mechanical speedo setup into a 4L60, just swap them. Why go to all the hassle of swapping the dash?
Omar, do you really need to replace the passenger dash too? Whoa...
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
If he wants to use his 90 gauge cluster, then yeah, he will have to replace ALL of it. But like you said, Kevin, it's not the only way.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Vintageracer
08-11-2015 08:13 PM
