Rolling back or Stopping Digital Dash Odometer????
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You can't. The milage is stored on a chip on the cluster board. You maybe able to reset it, but then is will display an error and you will be screwed. You can't disconnect the VSS either, the car won't run correctly. Sucks doesn't it... now an analog speedo... those are a sinch!
- 89 Formula 305 WS6
SFC's, LCA's, Air Foil
Spohn Panhard Bar
Flowmaster Cat Back, Tranny Cooler
A/F Ratio Meter (not a mod but it sure spurs interest)
Trans Temp Gauge
Most "Free" Mods
3:73, Zexel Torsion Posi - 90 Eagle Talon 2.0
(Winter Beater)
Mods? Um, no
The_Phoenix
02-04-2016 07:10 AM
Sanjay
08-12-2015 03:41 PM
beachrodder
08-07-2015 04:27 PM
