How do you run bright parking lights like the late 4th gens.?
Car: 1991 GTA Convertible
I have a Trans Am that I would like to wire up the front parking lights to be bright like the later 4th gens. I don't want to have them like daytime running lights but rather have them come on with the parking lights (like normal). I would like them as bright a light when they flash with the turn signal, still having the turn signal operational of course. Is this possible? What would I have to do to go about doing this? Thanks.
Joe
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Joe
No one I've talked with has said it's possible. I'm currently working on a solution for it, but it's slow in coming. I'll email ya if I ever figger it out.
Kevin-87 Firebird 2.8 A4
Ported Intake, K&N, !Cat, Cutout coming soon...
Best 0-60 10.26 seconds...for now
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Here's a schematic for adding daytime running lights....It uses the bright filaments in the front turn signal / running lights for turn signal and DRL function. The schematic is located at:
http://albums.photopoint.com/j/View?...907&p=42204509
Tim
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11793907&p=42204509">
Tim
[This message has been edited by Tim Burgess (edited May 01, 2001).]
Tim
Tim
Is it possible to switch the connecting wires on the back of the light?
To clarify this:
The end result would be the bright blinker filiment would be on all the time.
Then when you went to use your blinker, instead of getting:
"Bright - Normal - Bright - Normal - ......"
it would get:
"Dim - Bright - Dim - Bright ....."
Would this work?
Thomas.
To clarify this:
it would get:
Would this work?
Thomas.
ok your original bulb is 1097, you can buy 2097 to replace..
the difference is 1097 is 10watts, and 2097 is 20watts. it will get hotter in the lense. so maybe drill a few holes in the front with a very small , maybe 5-32" drill so air can get in, and drill a larger hole on the bottom so water can leak out that incidentally comes in..
this works, i have seen it done. but dont blame me if something goes wrong. i will not be held responsible!!
good luck
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
good luck
Jarrad
TH-700R4
To answer Stoopalini, no this won't work because I accidentally did it when I replaced the light and when I would try to use the turn signal it would come on but not blink.
92camaroJoe
08-13-2015 06:07 AM
