How do I remove the turn signal lever?
The plastic on the lever broke so I'm trying to remove it, but I can't see how. Any tips? I don't want to break anything else trying to get it out.
Thanks,
Shawn
Thanks,
Shawn
Shawn, the entire lever is held by one screw that you get to by taking off the steering wheel and then the lockplate. If you don't have the correct tools, buy or borrow them. It will make the job much easier.
After the lock plate is off, you'll see the screw at about the 8 o'clock position.
You will have to drop the plastic panel above your feet and disconnect the wire that runs from the lever to near your feet (through the column). This is the cruise connector.
The signal lever and wire will pull right out.
When you put the new one in, run a piece of stiff wire (connected to your new connector) down through the column. Makes it much easier this way.
Its not a hard job (other than the steering wheel and lock plate removal).
Oh yea, how did the group purchase on the intakes finally work out? Any left over?
jms
jms
Fronzizzle
03-18-2019 08:29 PM
