what is this plug for in my trunk??
hi,i just noticed i have a plug that's not plugged into anything in my trunk. it's a 91 camaro rs convt. it's real thin, and has two wires attached to it. one is solid black, and the other one is red with a white stripe. it has these letters on the plug.
10 PED
ab cde
my tonueu thing don't release with the switch at all, could it have something to do with that. where does it go, and what does it do? hope you can help. thank you.
10 PED
ab cde
The "10" is the body size of the connector. The "PED" is the acronym for Packard Electric Division (GM/Delphi electrical wiring division). The colors would have to be researched on a chassis wiring schematic, and mine don't necessarily cover the '91 year. I'm guessing that it is either for a rear hatch release or rear cargo well lamp, but it could be a license lamp, third brake light, etc. I wish I had a good chassis manual.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Later,
Vader
My GM '91 service manual lists a red/white and black/orange wire connected to a two-pin connector for the rear cargo compartment light.
If memory serves, that is the only two-conductor receptical in the rear. The main power (from the lid fuse) goes to this connnector (via a red/white wire), and another red/white wire (later changing to a bark blue wire is connected to this wire to power the hatch pull-down unit. The other side of this two-pin connecter (black/orange which then changes to just a white wire) goes to the hatch pull-down unit to turn the light on/off.
On mine, there are a total of three wires connected the connector described above (two +12 from the lid fuse and the other switched ground to turn the light "on")
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
[that is probably for your center brake light in the rear deck lid the tonnou cover is powered(mine is) check to see if the third brake lite works, if it does, it plugs into the trunk light...
91 firebird vert
tan top&interior
305/700r4<br>MY SITE HERE
91 firebird vert
tan top&interior
sorry guys, but my spoiler light, and trunk light is already hooked up and working. i don't have a clue where it could go, and what it would do, but i do appriciate the help from you guys. i'm gonna try to follow it today to see where it goes.
89 formula TPI
09-07-2015 11:06 AM
Glowsock
09-05-2015 07:48 PM
