hi/lo beam switch
hi/lo beam switch
Is it very difficult to change this switch? Have not had the car (91 RS) very long and have not had a chance to work with it much. Thanks. BTW - great forum, have already picked up a lot.
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
my opinion is big pain in the *** ...
have to remove the steering wheel and worry about the re-alignment of it when re-installing.
Need a couple of specialty tools for removing the wheel and compressing the spring (for the locking device when off) and reusing the latter tool when replacing the spring.
But mentally...easy job.
it is easily acomplished by anyone who know knows the difference between a torx and a phillips screwdrivers.
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Duffster (age 32)
AND THE TIRES:
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
What exactly is your problem? Are you not able to select between hi/lo because the switch will not engage, or are you able to engage it, and the switch just does not work?
KAM
KAM
Thanks for the replys. Kam - to be honest I am not totally sure. Got the car from my younger brother. He said that the lights did not want to switch back and forth, and that a couple of times he lost all headlights. Have been enjoying the car too much to get into that until now. I at least have low beams. Will hopefully have some time this weekend to tinker with it. Have gotten several good ideas from this forum to try out. Later.
On a T/A there is a switch box halfway down on top of the stering colume that the acuater rod hooks to that turns your light to bright/low
right next to your egnition switch box, it could have move down or screws come loose if it is like a T/A. Hope this will help some.
On my car, the wire that is for the cruise control was physically interfering with the hi/lo beam actuating motion of pulling the stick back towards you. i just pushed it out of the way and all is well now.
stephen - 89 GTA - https://www.thirdgen.org/rides/index...ew&rideid=1321
Checked the switch out. Only seems to do it if the wheel is tilted down. Otherwise, works fine. Thanks again for the help. May get into it more in the future. Sully
Car: '91 Z28
Axle/Gears: 323's
Sounds like the hi-beam switch is out of kilter on the column. Mine was the opposite - only worked with the wheel tilted up. The switch is located at about the 11:00 position of the column (facing the column), way down in there by the fuse block. It has (2) 1/4" screws on it that are a pain to get to, but all you gotta do is break them loose and adjust the switch and tighten them back down. It's easier to get to if you let the column down with the (2) 13mm nuts under the gauge cluster...
KAM
KAM
OK, I finally had the same experience that my brother had with the car. Driving down the road Saturday night with the high beams on. All of a sudden, they start flickering back and forth between high and low( even the indicator on the dash was switching) and would then go out. Switched back to low beam and they were just fine. Thunderstick, I still am going to check the switch like you said. Didn't get too this weekend, spent Sat. flushing out the cooling system then most of the day Sunday working on the girlfriends 85 Z28.
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
Ladderman, I would go ahead and replace the switch while your down there. Make sure the dealer doesn't try to sell you the multifunction stalk switch ( over $100 ), the dimmer switch sould be less than 20. It's is a bit of a pain in the rear to get to, and since your car is 10 years old, you don't want to have to do it again any time soon.
85 Z28 LG4 with 224,000
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
Randomtask2
09-10-2015 08:37 AM
