Swapping from a 6K tach to an 8K tach!! Question within!
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
My car currently has a 6K tach and I've found an 8K tach out of a GTA!! Can I just unhook my tach and hook this one up in it's place ...the same way the old tach was hooked up and be done with it...or does something else need to be done too??? I've never changed a tach so honestly I don't even know how they hook up!! Any help would be greatly appreciated!!
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
As long as both engines have the same number of cylinders, you'll have no problem.
Pete
Pete's Place
HiOutput Tech Page
83 SC
206+k mile LG4/5-speed
14.935@94.14
Pete
Pete's Place
HiOutput Tech Page
83 SC
14.935@94.14
<font face="Verdana, Arial" size="2">Originally posted by Petes 84Z28:
Pete
</font>
Pete
</font>
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I think you ment to say 1989 but the V8 cars also came with a 8K tach.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated) SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,free mods.
G-Tech times
0-60 5.3s
E.T. 13.91@104.8MPH (2300ft)
G-Tech times
0-60 5.3s
I believe the Turbo GTAs had the boost gauge built in also! This setup is the entire gauge cluster and doesn't have the boost gauge so I'm pretty sure it's the one from the V8 GTA!
