Buzzing coil?
Old 03-13-2001 | 01:20 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Buzzing coil?
I just did a tune-up on my 92 LB9, and while i was messing with the timing i noticed it seemed like my coil was buzzing/popping. Almost sounded like the injectors, but a little different, and definitely RPM dependent.
Otherwise it runs great/clean, no missing. Is this the first sign of my coil failing, or maybe it was my imagination / frustration of trying to get to thet hold down bolt on the distributor making me think i heard secondary voltage leaking.
...ed
btw, i want to meet the commie that decided to go with small cap distributors again on GM cars so i can kick his *** . I didn't need to be reminded that HEI hurts when i popped a plug wire off while setting the timing, large caps distributors at least have that nice wiring bulkhead to use.
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old 03-13-2001 | 07:55 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Mine is very loud and annoying from the drivers seat, but I also, without thinking ahead, mounted it to the firewall.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Fanatic1074
10-03-2022 05:57 AM
RedLeader289
05-28-2019 01:47 PM
school boy
10-22-2015 11:47 AM
92rsvortec350
19
10-09-2015 09:39 AM
Giocio
10-01-2015 12:20 PM
Quick Reply: Buzzing coil?
