Cure for funky acting tach after MSD coil install. ?
I understand there is some sort of "tach filter" equipped on our cars. What do I do to cure my tach from acting like it's on crack.
(hey that rhymed)
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
(hey that rhymed)
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
One thing you might want to look at is the wires coming off of the coil (not the coil wire itself). Make sure that there are no cracks or anything wrong with the wires. I had one of the wires from the distributor to the coil that had a cut in it and you could see the wire a little bit. This little bit of exposure caused my tach to jump around all over the place. Replaced the wire and never had a problem since. This might not be the problem but I hope it gives yous some direction to go in.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
RedLeader289
05-28-2019 01:47 PM
school boy
10-22-2015 11:47 AM
