Radio Whine
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Is the head unit connected to a remote amplifier? If so, does the noise go away if you disconnect the audio lines between the two units (with the amplifier powered)?
Tim
Tim
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
There is a cap in the disributor (sp?) that might have crapped out on you. It kills line noise for the radio, i am not sure if it replacable, but check. Also, check the ground for the radio. If nothing helps, you can buy noise suppressors at audio stores... pick one up, that should fix it.
- 89 Formula 305 WS6
SFC's,
LCA's,
Air foil
Flowmaster cat back
Tranny Cooler
A/F Ratio Meter (not a mod but it sure spurs interest)
Trans Temp Gauge
Most "Free" Mods - 90 Eagle Talon 2.0
(winter beater)
Mods? HA! its a rice burner!
The device that you may be referring to is mounted near the distributor cap in some configurations - it's a tach filter.
Does the noise occur while the radio is on the AM or FM band? (Probably normal on the AM band). Does the system voltage at the radio dip low while operating the window motors? Does operating either window motor cause the noise in the radio, or just one of the motors? Pull the radio & check the connections & the antenna plug & cable. Try wiggling the wires while operating the window motor & see if the noise is intermittant.
Tim
Tim
Gunner242
12-25-2015 04:49 PM
