Barometric Pressure sensor (location??)
heya all, i've just retreived a code 32 off of my T/A..
it's guiding me to the Barometric Pressure sensor, with the limited time i had back at the shop, i couldn't find it anywhere!
i looked into the Mitchell Book for location and it tells me "Located on right side of the firewall in the engine compartment"
but while checking the right side of the firewall i couldn't find it at all.
is it near the engine itself or is it near the blower motor?? or where is it..
if anyone can help it would be totally appreciated.
Its also called the map sensor, im not sure what year your car is but on carb and TBI models its on the fire wall to the right of your ac/heat blower motor or just to the left of your distributor. You cant miss it, its got a vaccume line and a three wire connector going to it.On TPI models its on the side of the plenum (passenger side)toward the back. Hope this helps.
hey thanks for the help, duh i should of put down what my car was in the first place with the year, perhaps that could of helped hehe.
it's an 87 Trans am with a 305 tpi
anyways, thanks for the info.
i'll try to look for it tommarow.
i knew it was somewhere down there, i just didn't look hard enough, i mean i couldn't find it anywhere near the fire wall on the right side, but i'll try to find it where ya told to me took for...
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Actually, a barometric (baro) pressure sensor monitors the atmospheric pressure, while a MAP (or vacuum) sensor monitors manifold pressure. Are you sure that it's a TPI? Barometric pressure sensors weren't used on an '87 TPI setup - only in carbureted configurations.
Tim
Tim
9192camaro
16
02-03-2019 12:21 AM
R3500
08-17-2015 12:16 PM
