Computer Type?
Car: 2014 Camaro 2SS/1LE
Engine: 6.2L LS3
Transmission: Tremec TR6060
Axle/Gears: 3.91
Computer Type?
I hooked a code reader up to my terminal and it says it's not responding, but I can jumper it and get the code. The reader works just not with this car. The car have over 200,000 miles... Chances that the motor is changed is pretty good. The code reader wants to know the 8th and fourth digit of the vin number. What are my options to find a type on the computer to match it up to a year? Are maybe some of the pins different on this terminal from other years? BTW it's an 87 ta tpi.
Car: 1985 Trans Am
The 4th digit should be an "I" for 87, I know the 85 is an "F" but they skipped either "g" or "h" in 86, and the eighth digit is an "F".
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Kevin Irving
Engine: 6.2L LS3
Axle/Gears: 3.91
I know the vin for my car itself, but I'm not sure that the engine and computer are from the same car? Is there anyway to tell that, by maybe number or the block, heads, or computer itself? Also does anyone know if the pins for all the tpi computer terminals were the same? Maybe that's was throwing it?
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by Fiero_Freak:
I know the vin for my car itself, but I'm not sure that the engine and computer are from the same car? Is there anyway to tell that, by maybe number or the block, heads, or computer itself? Also does anyone know if the pins for all the tpi computer terminals were the same? Maybe that's was throwing it?</font>
Kevin Irving
Engine: 6.2L LS3
Axle/Gears: 3.91
Great... Thanks. I'll give that a try and see what I can come up with. Maybe I just need to check the continuity of the terminal while I'm I have the ecu out.
Engine: 6.2L LS3
Axle/Gears: 3.91
