Need to go to speedo cable from tranny to electronic speedo
Location: First one out of liberty city, burn it to the ground
trans is from 87 firebird. I have an 89. my speedo is electronic, the trans needs a speedo cable. What are my options? The speedo cable is only 5 bucks so its not bad, but im more thinking of what i can do to go from the speedo cable then to my electronic speedo.
89 Firebird (AKA "Money")
2.8 V6 w/ t5 tranny (383 tpi t56 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
Next:
Spohn Torque Arm, Lakewood Panhard bar, BMR Fabrication Sub Frame connectors...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Next:
My Site:
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why not visit the wrecker and get a used VSS for the transmission?
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 385 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Because you can always sleep in your car, but you can't drive your house.
i thought of that but there isnt a vss on the tranny just a spot for a speedo cable...unless u know something i dont?
Next:
My Site:
Next:
My Site:
All you need is the vss. The calbe drive cames out and can be replace with vss. I know because I have 87 camaro which was cable driven. but I but in a dash from a 90 camaro which is electric operated speedo. If I go over to the grage tonight I will get you the part number for it.
yea please. Did u order it from GM or go to like an autozone or something like that for it? BTW..how does the cable drive come out?
Next:
My Site:
Next:
My Site:
It's just the black plastic housing the cable is attached to. You take out the one 10mm bolt, and pull the piece straight out. There should be enough room to do it without removing anything first. The VSS is shaped exactly like it on the side that goes into the tranny, just with an electrical connector on the outside instead of a threaded nipple. Just make sure the gear color is the same as what you're taking out.
Actually, the VSS is quite a bit larger than the cable drive unit. Here is a picture of a VSS installed in my tranny with the connector attached: http://www.geocities.com/motorcity/g...oconnector.jpg
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
FORMULA 350 TK
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The hole diameter in the trans is the same whether it's an electronic VSS or the mechanical cable connection piece. Either type will fit in the trans speedo drive gear access hole.
Tim
Tim
topteam54
10-06-2015 12:21 AM
gta892000
09-16-2015 12:37 AM
