Build the radar Detector into the car
i wana build my radar detector into the car so its not visible trough the winshild its a pain in tha s$$ to have it on the window and plug it in and such... so i figured there has to be a way to build it in this probably isent a normal question jsut figured someone might know or tryed this i have a unidin 360 radar detector
Car: '89 TA
Engine: LB9
Transmission: M5
I don't know about BUILDING it in, but its fairly easy to at least hardwire the power into the ignition. Reply for details if you want. It'll take care of the annoying wire going into your lighter.
well hardwireing it is a part of this so i actually do need that information. where is a good place to take the power from and how to wire it.. i was thinking of takeing it from wires from the cig lighter but i dont really wana go spliceing thoes up.. so what ideas do you have?
allso .. i looked at the radar detecors manual and found out what the sensors are on it im gana take it apart today and see if i can un soder the connections and relocate evrything i think im gana put the lights and actaull radar detector unit in my over head concole. ill post pics when i get it setup. if any one is interested in seeing it
Dont Race Cops apparently you cant do that! -Dellz
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I just tapped mine into the fuse box. I cut the chord, and put two ends on it. The positive one I plugged into the Battery spot in the fuse box, and I just plugged the ground in where my dash assembly fits. I then ran the chord through the trim, where I just left the detector velcroed to the dash. If you put it in the corner, a cop will never notice it. I know because in our town its illegal to spin the tires and when I get stopped by the cops for it, they always ask me what the beeping is.
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
-=-Mike
got one easier for all of ya--Whistler make a three piece radar that is hidden in your front grill, the other piece hides behind your rearview mirror and the leds can be drilled into your dash or the small box hidden just under you gauges.
that would be perfect the actuall model of that radar detector is 3300 but its allso 330 bucks but thats installed hmmm and i cant find it ne where .. :T
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
K-40 makes one with 3 detectors, on for the fron bumper, the rear and a laser for the front I think. Then the control center is a small piece you can put in your dash and make it look factory. But it is well over $1k.
James
If the women don't find you handsome they should at least find you handy
James
1 Post
Car: 92 Formula
Transmission: A4
You do this yet?
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
92 Rs 3.1/T-5
Clarion Head Unit,
AIM : Theonekiztope
ICQ: 8787542
Nah hehe i opend up my old radar detector and i couldent figure out how to relocate the sensors plus i think there where reflecotrs involed i dont think it would work :T
