QUICK! Where is the flasher unit in my car???
I've been looking high and low for the flasher unit in my 1989 IROC-Z 'vert all morning. According to the Haynes book, it's supposed to be at the rear of the fuse box. It's not there. Am I looking at the wrong place or what? Please help!
1989 IROC-Z Convertible
305 TPI automatic
White with black top
Mods:
None to date... Working on it!!!
My webpage: http://mindspring.com/~humvee
305 TPI automatic
Mods:
I found it. It was hidden next to the radio and the A/C controls. Anyways, I replaced the flasher unit, and they STILL DO NOT work!!!
Here is how it goes. The harzards lights work fine, they flash. The turn signal do not flash, they just stay on. I checked around the car when the turn signal is constantly on, all the bulbs lights up. What the heck is making the flasher not flash?!? Please help! Going nuts!!! [ ]
305 TPI automatic
Mods:
305 TPI automatic
Mods:
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Check for a bad bulb in the system - if it's not the flasher, it's usually caused by a bulb - front or rear.
KAM
KAM
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
just a suggestion...
pop down that console you found the flasher in....lay on your back....and look up above that console......JUST IN CASE!!!!!
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Remove the flasher unit that you changed out & see if the 4 ways stop working. If they do, you changed out the 4 way flasher, instead of the turn signal flasher.
Tim
Tim
I went back to the turn signal unit and tested it. You guys were right, I accidentlly put the turn signal flasher into the hazard flasher slot. Anyways, I found the right place for it and it STILL doesn't flash! I checked the bulbs up front and they were fine. I couldn't get to the back ones because one of the bolts that the wingnuts are one basically became part of the car. Can one single bulb cause both sides to go out or does it mean there is a bad bulb on both sides? This thing is still driving me nuts!
305 TPI automatic
Mods:
305 TPI automatic
Mods:
1 bad bulb would only affect 1 side, 2 bulbs (1 on each) would yes kill your system.
I would recommend checking your flasher again... make sure you've got the right one, or the connection isn't still loose or something.
Just because the flasher fits and the dealer says its the right one, don't mean squat
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
I have that exct same problem. the passenger side flashers don't work. only tha back one turns on, dosn't blink.
hope you find it in time. i just try not to make right turns
1 Post
Car: 92 Formula
Transmission: A4
Heres something weird.....
I had an 88 Grand am a couple of years back that had problems with the flashers...
all the lights lit up, but they still didnt flash.
I changed the actual bulbs anyways, and guess what! They worked!
I dont know if it was the actual bulbs or not, but maybe the connections were loose or something..
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!! (New thing!)
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (17:24:14)
"No one knows until they learn" Leon Calrinsky (99)
92 Rs 3.1/T-5
Clarion Head Unit,
AIM : Theonekiztope
ICQ: 8787542
Ghettobird52
07-05-2024 11:18 PM
db057
08-11-2015 10:11 PM
