Battrey drain?
Old 11-10-2000 | 12:41 AM
Ggarso's Avatar
Battrey drain?
If I take the positive off of the battery and put a ohm meter on the cable and to ground it shoots up. I have had to jump the car every day the battery is dead if it sits for three hours or more. Can the starter cause this?
Thanks, Gary
1990 Formula 350
Old 11-10-2000 | 08:31 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Do a search on "battery drain" in the electronics section. There are a number of posts that address this problem.
Tim
Old 11-10-2000 | 06:12 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
sounds silly, but try removing all the fuses...
have someone watch the ohmmeter and re-install the fuses 1 at a time...
Old 11-11-2000 | 07:56 PM
Ggarso's Avatar
What sounds silly? That is exactly what I did pulled the fuses and someone whatched the meter.
1990 Formula 350
Old 11-11-2000 | 11:06 PM
Duffster's Avatar
................and?
Old 11-12-2000 | 06:55 PM
Ggarso's Avatar
What is the fuse marked ARC it doing most of the drain. OK I have taken the starter off and the wires on the starter are doing this. 1 has a slight ground with all fuses removed. 2 has no ground until I put the ARC fuse back in.
These are orange wires from the starter that run up the block and the next to the intake to the back of the motor.
1990 Formula 350
Old 11-14-2000 | 09:08 AM
The 20 ampere ARC fuse supplies continuous 12 volt battery power to the radio (orange wire).
Tim
Old 11-14-2000 | 09:43 PM
Ggarso's Avatar
Thanks, Tim
SRKLEGIN
10-29-2015 07:38 PM
85cmroz28
10-04-2015 10:44 PM
raymondandretti
09-27-2015 07:43 PM
ericjon262
09-11-2015 07:07 PM
89 formula TPI
09-07-2015 12:06 PM
