Homer Simpson TurnSignal Flasher Question
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
possibly 3-5 inches directly above the computer connection for your ECM...just above your right knee???
I've found the emergency flasher in there, away from me. Towards me is my warning beeper. In the middle is a white, 3-pronged cube. Is THIS my turn signal flasher? If not, anyone know what it is?
Okay, it's the horn relay. The computer at the parts store says it's on the upper passenger side of the steering column brace. I can't find anything there. Has anyone ever SEEN one of these things?
above the warning center and hazard......litterally in the wall, look up there...for the other relay.....
"Patience young Luke..."
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The turn flasher may be "dangling", connected to a small plastic connector, with a dark blue & purple wire connected to it. It may also have a metal clip around the flasher & may be clipped to anything, near the pass side of the column, as was mentioned above.
Tim
Tim
