What size battery?
Car: 1992
Engine: 350TPI
What size battery?
what group size is the battery in a 3rd gen? i want to get a Optima, and there is 2 different sized red tops, a 75/35/25 and a 800U. thanks
Der Zerstörer
1992 350TPI GTA
Metallic purple
17" rims, dual cats
3.73, no traction
Eibach springs
[This message has been edited by Zerstörer (edited October 11, 2000).]
Der Zerstörer
1992 350TPI GTA
Metallic purple
17" rims, dual cats
3.73, no traction
Eibach springs
The group size is 75, although you can put just about any battery you want as long as it can fit. Also 75 series batteries are sidepost, as like all GMs. Unless you change your cables, then you need a side post battery.
Steve
1988 Chevrolet Camaro IROC-Z
Steve
Get the Optima. Mine was a tad too large for the tray, which I solved by using an alternative holddown method.
BTW the Optima is top and side mount, so no new cables are necessary.
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
I've heard a rough number before that you want 2 times as many CCA(cold cranking amps) as you have cubic inches engine.
