Spohn K member, A Arm and spring issues.
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Since I heard that the K member and A arms llower the front, I went with eibachs to maintain stock height. Car was 27.5 from ground to fender on both sides stock. After the eibachs went in long with all the new stuff the driver side went down to 26 and the passenger side went to 26.5 I said hmm why is the passenger side still higher. It looks like I didnt index the spring all teh way missin gmy mark by about an inch but said let me throw back in the ws6 springs. I threw in the driver side spring and was greated with 27in while the passenger side with the eibach still showed 27.5. I was like wtf. Why is it still higher. I got around to doing the other side today with the ws6 spring and drove around and saw my gap on the driver side to 27.5 and the passenger side over 28..... thoughts? Everything is installed correctly. I dont have my front swaybar on yet if that makes a differance same with needing an alignment, My toe in and tow out and camber is all over the place. Anything to check on the K member and arms for out of alignment?
ambainb
04-25-2016 09:21 PM
