BIN to bin_lib but unsure which to pick
I have 91 SD car.Originally a 305 5spd,now it a 355 5spd. I went to the bin_lib and found the 1227730 folder and from there I choose the 90L98man8D.bin. First if I reading it right it's for a manual car second I thought it was 350.So I make a few changes on the prom put it in my car go down the highway in 5th gear and my shift up indicator tells me to shift but I have no more gears do yeah see my point.So I'm gonna take a stab in the dark and say this is for a 6spd.Also I get a oil temp code every once in awhile So my question is do think I should pick a diferant bin,or should just forget about that shift light and and keep going.Unless there's something I'm missing(which is very possiable) there were only 3 bins I could choose from.If I learned any thing I think the bin I'm using is one for a Vette right or wrong
90350cam8D.Bin
90L98MAN8D.Bin
91gta305A48DBin
90350cam8D.Bin
90L98MAN8D.Bin
91gta305A48DBin
Well since posting this topic I did some more reading and as I already figured I want a manual bin as my base.But out of those 3 I found tochoose form te one is an Auto one the other one(90350cam8D) leads me to believe it's an Auto as well since I don't know of any 3rd gen's having a 350 with a manual.So does this mean I should just keep using the 90L98MAN8D.Or isthere somwhere else I can go to look.I keep loooking but any help would be great
Well since posting this topic I did some more reading and as I already figured I want a manual bin as my base.But out of those 3 I found to choose from the one is an Auto one the other one(90350cam8D) leads me to believe it's an Auto as well since I don't know of any 3rd gen's having a 350 with a manual.So does this mean I should just keep using the 90L98MAN8D.Or isthere somwhere else I can go to look.I keep loooking but any help would be great
My recommendation is to work with this bin, and refine it for your applicaton, as it contains code for a manual that makes them easier and more pleasant to drive.
Just modify your existing bin to make allowances for more cubes. Since I run a MAF, I dont know where to tell you to start modifying...but injector constant is probably a good start (you did get bigger injectors, right?)
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
raymondandretti
09-27-2015 06:43 PM
FueledSoul
09-26-2015 12:00 PM
