Pump Shot 32B
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Pump Shot 32B
I just got my wide band o2 hooked up and wow this thing is too sweet. Anyway after a little tuning with it and a couple of burns I knowticed that the pump shot was taking me way to rich like 10.5 and if i hit two pump shots in a row i go to like 8 (Yes I know i Play with my car too much). My question is where is the pump shot table on the 32b code because tunercat doesnt have it on there. Try to explain it as simple as possible because I always get confused when it comes to hex editing.
1 Post
Car: An Ol Buick
Engine: Vsick
Re: Pump Shot 32B
Engine: 383 4 bolt
I tried the arap bin but i had starting problems. I played with it for awhile and posed a few things about the problem but never could get the bin to work corectly. Maybe ill try a bit more. Ok I just looked at my 6e tables in tunercat and there is still no pump shot. Hmmm
1 Post
Car: An Ol Buick
Engine: Vsick
IF you use the ARAP this might help you
Bruce
; >>> Delta TPS Accel Enrichment <<<
; Tables & params
LC326 FCB 32 ; 0.125, Trans TPS filter coef.
; Cal = Arg * 256
LC327 FCB 10 ; 3.9% Min Diff TPS for Pwr Enrichment
; Cal = Arg * 2.56
LC328 FCB 10 ; 3,9% TPS, Zero Async Accel Enrich if Neg Diff TPS > 3.9%
LC329 FDB 0111 ; 1.69 msec Min Async Pulse Width
Cal = msec * 65.536
LC32B FDB 0364 ; 5.5 msec Max Async Pulse Width
Cal = msec * 65.536, (5.55 Msec)
LC32D FCB 1 ; Cal of Injects in fuel limiting
ACCEL ENRICHMENT FACTOR % BPW INJ (0-4)
TBL = FACTOR * 64
MULT A.E. PULSES
LC32E FCB 32 ; 0.5 1
LC32F FCB 32 ; 0.5 2
LC330 FCB 32 ; 0.5 3
LC331 FCB 32 ; 0.5 4
LC332 FCB 32 ; 0.5 5
LC333 FCB 32 ; 0.5 6
LC334 FCB 32 ; 0.5 7
LC335 FCB 32 ; 0.5 8
PWR ENRICHMENT TABLES & PARAM'S
TYPE $6E
LC4FD FCB 50 ; 50, IF Ld VAL GT THRESH, ENAB PWR ENRICH
LC4FE FCB 10 ; 10 Ld VAL HYST FOR PWR ENRICH.
LC4FF FCB 16 ; %TPS HYST FOR PWR ENRICH.
LC500 FCB 213 ; 119c COOL, FOR TPS TBL THRESH SEL, (HOT or NORMAL)
PWR ENR TPS THRESHOLD vs %TPS
FOR COOLANT G.T. 119c, (LC500)
*** WOT ***
(SEE LC500 FOR COOL THRESH)
TBL = 2.56 * %TPS
%TPS RPM
LC501 FCB 180 ; 70.3 400
LC502 FCB 180 ; 70.3 1200
LC503 FCB 180 ; 70.3 2000
LC504 FCB 180 ; 70.3 2800
LC505 FCB 180 ; 70.3 3600
*** WOT ***
TBL = 2.56 * %TPS
; %TPS RPM
LC506 FCB 180 ; 70.3 400
LC507 FCB 180 ; 70.3 1200
LC508 FCB 38 ; 14.8 2000
LC509 FCB 38 ; 14.8 2800
LC50A FCB 38 ; 14.8 3600
Bruce
; Tables & params
; Cal = Arg * 256
; Cal = Arg * 2.56
Cal = msec * 65.536
TBL = FACTOR * 64
MULT A.E. PULSES
TYPE $6E
*** WOT ***
TBL = 2.56 * %TPS
%TPS RPM
*** WOT ***
TBL = 2.56 * %TPS
; %TPS RPM
CarGuyDennis
137
12-06-2016 11:02 PM
ambainb
04-25-2016 09:21 PM
