DB9 Serial Plug
DB9 Serial Plug
Well, I WANT to make the cable to use with WINALDL, bbbbbbuuuuttttt, NO ONE sells the DB9 serial connector!!! NO ONE! Who online sells them, and whats there web address? Thanks!!
Car: 1982 Z28
Your local Radio Shack should have plenty of DB9 connectors in both the crimp pin and solder pin variety.
Grab a DB9 female. I recommend the crimp pin type, unless you're a soldering whiz with a lot of patience.
Car: 1982 Z28
Probably both...for what retail shops pay they don't usually get the top of the class.
Look on the shelves, I've bought DB9 and DB25 connector kits at Radio Shack in the recent past.
If no luck, DigiKey or BlackBox can help but you may spend more on shipping than on the parts.
I checked BlackBox.com and found the following part numbers:
FA120 DB9 female crimp connector $1.49,
FA820 pack of crimp pins at $0.19,
FA130 plastic hood $1.95.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I've got some extra. Lemme know if you need, I can snail mail you something.
wigmobile
09-17-2015 03:38 PM
89 formula TPI
09-07-2015 11:06 AM
