ECM Dump Moates Software
What hex values should I use when using the dump function in Craig Moates sofware? I have a 730 ecm. I've tried a few numbers including 0 - 32767. The default values only get a 18k file and I think I'm supposed to get a 32K file.
After getting this file it should be able to be read from winbin, right?
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Should go straight to Winbin without a problem.
The memory range for the 165 ought to be hex C000-FFFF (49152 to 65535 or 16x1024). For The 730 it should be 8000-FFFF (32768-65535 or 32x1024).
Hope this helps. If anyone knows different, let me know. Tell us how it turns out.
efiguy
09-27-2015 01:30 PM
