LEDs tapped into injector wires to monitor fire rate?
1 Post
Car: 91 Red Sled
This isn't exactly eprom but it has to do with GM ecm injector drivers. Is it possible to install 2 switching transistors inline of the TBI injector wires to monitor injector behavior from inside.
I was thinking about the transistors because I remember somebody telling me that the LEDs have a voltage drop. Anybody see any problems with my plans? Any recommendations for what kind of transistors would work best.
1 Post
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
LED voltage drop is around 1.5 volts. Current draw is as high as 30mA. Use a dropping resistor. Wire resistor (I suggest 470 ohm) and LED in series and connect to wire leading to solenoid. LEDs will probably just flicker.
db057
08-11-2015 10:11 PM
