Anyone interested in an Excel file for graphing winaldl loged data?
Old 01-14-2002, 12:49 AM
JPrevost's Avatar
Car: 91 Red Sled
Just curious.
Old 01-14-2002, 01:22 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I would love to get m hand on it.
Do you know where to get it?
Thanks.
Old 01-14-2002, 02:52 AM
John Boy's Avatar
Me too please.
Old 01-14-2002, 03:05 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Yup
Old 01-14-2002, 07:50 PM
steve8586iroc's Avatar
Add me to the list.
Old 01-14-2002, 07:52 PM
JPrevost's Avatar
Car: 91 Red Sled
Okay, I'll put it together in a user friendly macro of some sort. I might end up using a plug-in for excel but if that happens I'll make sure to tell you guys how to do it in another post.
Old 01-14-2002, 08:11 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Thanks and can not wait to see it.
Old 01-15-2002, 01:50 PM
MrDano's Avatar
Car: 1987 Monte Carlo LS
Engine: 357 TPI, LT4 hotcam
Would the macros be useable with the logs that are created with Craig Moates software. I would love to see it if it is.
Old 01-15-2002, 02:54 PM
Beast4's Avatar
Add one more that thinks that it would be a very cool thing!
Old 01-19-2002, 03:25 AM
JPrevost's Avatar
Car: 91 Red Sled
Well I figured the easiest way to graph/chart the data with excel. Only problem is that there is so much to graph that it would be too confusing for me to actually make a macro.
The problems are the data length but I think I can work around this. Infact I know I can get around it, I just need to figure the simplest routine to do so. The other problem is what data YOU want displayed with what. I can compare and contrast. I can make 3d graph of the BLM and MAP/RPM but it isn't good if you have over 500 data logged rows!!!
I might just end up making a detailed technical article OR work with Jonas and do some nifty source code editing. Whatever happens I'll have this done soon. I'll post some pictures later but it's 4:30am and I'm trying to rid my blood stream of the booze.
Old 01-28-2002, 04:01 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
ttt
Old 01-28-2002, 10:19 AM
HighHopes85's Avatar
JP-
I recently wrote macros for myself that acted similiar (I think, can not be sure) to VEMaster for the 7730 ECM. The file ended up being over 40 MB in size. I realized it was too large to share with others, and I was able to shrink it down to 80KB by adding one more macro. I haven't worked on that project for a while, but if you know VB, I can send you the macro code and you can take a look at how the macro was written. Regards, -Matt-
EDIT-BTW, my file took 8000 data sets and manipulated them. I had a separate file for lower VE and upper VE so I could just copy and paste into TC editor. Since it used 8000 data points, THAT is why I needed the extra macro to shrink the file size down from 40 MB to 80KB.
Old 01-28-2002, 05:32 PM
JPrevost's Avatar
Car: 91 Red Sled
It's funny, I didn't know VB code was all that hard until I tried adapting. I'm teaching myself the language but I'd love some source code to play with.
Send it my way. For the time being I'm just going to write up a tech article that explains how to graph/chart only the data you want to display. The hard part is trying to use pulldown menues and having them manipulate the chart's x axis. I'm pretty close to a final piece but I've got 3 exams in the next couple days.
I haven't forgoten, it's just taking a while .
F.I. 57 Belair
08-23-2021 01:09 AM
PurelyPMD
05-05-2016 04:57 PM
camaro1185
10-26-2015 06:51 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 08:28 PM
IROCZDAVE (88-L98)
09-17-2015 07:43 AM
Quick Reply: Anyone interested in an Excel file for graphing winaldl loged data?
