$6e xdf code 36
Re: $6e xdf code 36
Address of mask for error flag for code 36 should be 0x1DF (bit 7) for both $6E and $32B. Shown in disassembly as 0xC1DF:
LC1DF FCB $EB ; 1110 1011, Mask For ERR flag 3
; b0 = Err Code 51 Prom Error
; b1 = Err Code 46 VATS Fail
; b2 = Err Code 45 o2 Sensor Rich
; b3 = Err Code 44 o2 Sensor Lean
; b4 = Err Code 43 KNOCK Fail
; b5 = Err Code 42 EST Monitor error
; b6 = Err Code 41 CYL Select error
; b7 = Err Code 36 Burn off Diag.
Re: $6e xdf code 36
I can see now how tuner cats is messing up the tune. If I select malf 36 it disables it properly. If I also do vats delete that’s where it changes the injector flow rate slightly and changes stoic afr.
odd but another reason not to trust tc.
