Diode
Diode
On the 2 tansistor cable I can't find the 1N4148 diode at the local radio shack. Is there any suitable replacement?
165 ECM in an 88 formula using moates software
If you can't find those either let me know, I have a few 1N4148's lying around that you can have. That way you won't have to pay some companies stupid base shipping fee for something that could be sent in an envelope ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Whoa, just realized you're just up the interstate from me, probably only take a day or so to mail them.
any small signal diode with a PRR of 20 volts or higher will work
there are hundreds
even a radio shack empoyee should be able to hook you up with some thing
any of the 1N400X series will work
there are hundreds
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 IROC-Z
Engine: 355 TPI
I thought I would chime in here. I wouldn’t use one of the 1N400X diodes as they are designed as a rectifier diode and the 1N4148 is a high speed switching diode. Radio Shack sells a 1N914 that is a direct cross to the 1N4148, and their dirt cheep, like $2.50 for 50 of them. Some will tell you to leave that diode out, but it is there to eliminate the reverse bias condition from the BE junction of the transistor. With out that diode there is a (vary, vary slim) possibility of developing a “leaky junction” in the transistor. It’s cheep insurance. This type of failure is vary hard to fine when trouble shooting.
Long story shot; go get some of the 1N914s from RIP Shack….
