$6E Tuning Tips 4 Laymen any interest?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Well I am getting close to my tune and be abel to drive. And form 6 months ago I have come a long way with stock 305 88 auto from $32 to $6E injectors and going through all the tables. Any interest in write up, without being flamed for my lack of expertise in code, but from a laymens perspective of what worked for me to get to a drivable tune from
MAF Tables
Inj constant
fuel pressure
inj swap
Spark/AE/PE tune
all this was with NB and I am hoping to have my WB installed next week to start more testing. I couldnt have done it with all the support of TGO but I am getting good tire squealing results on a stock 305 so much so that for a fun cruiser I do not even think I want spend more $ to get bigger engine just new muffler heads and rollers to replace the beat up stock ones and call it a day
MAF Tables
Inj constant
fuel pressure
inj swap
Spark/AE/PE tune
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: $6E Tuning Tips 4 Laymen any interest?
That thought passes quickly when the Summit catalog shows up!
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
Jp
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
I am very interested to hear about the process you went through, any specifics regarding the application of tuning theory would very much appreciated. For example, how did you change the timing table. Did you just globally add to the table until the engined knocked, did you smooth the table, what smoothing factor did you use in tuner pro etc. Thanks in advance
Andrew Prakash
09-08-2015 11:48 AM
