Injector duty cycle with TunerPro, this right?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I'm running a little lean with my new setup, my injector BPW is showing 10-11 past 6k rpm in TunerPro and I'm wondering does this get divided by 2 since it is batchfire? Basically anything over 10 at 6k is 100% dutycycle. I'm running code 59 for my setup with 60lbs injectors and afr usually stays in the 11.8 range but after a new pulley change with more boost I'm getting up to 12.7 past 6k. Not sure if my 255lph pump is at its limit or the injectors are to small and I need to pump up the fp to bring the BPW down some. Though you would think 60lbs injectors would support this engine no problem
Car: 89 GTA
Re: Injector duty cycle with TunerPro, this right?
So I got some help on code59.org with my question and looks like I'm running out of injector and my duty cycle has been maxed out. I suspect I hit the limit of my fuel pump. Once I get my car all put back together after this cam change, I have a new auto meter fuel pressure gauge to setup and hope to see what's going on.
When i went thru this exercise i was told batch fire you multiply the calculated duty cycle % by 2.
In my case my log shows 8.91 pulsewidth at 5775 rpm. Thats 42.88% by the calculators online but since you fire twice its actually twice that or 85.76. I dont know if i believe that but maybe its right, for me that seems high running 115 lb injectors and only 15 psi boost.
11.7-11.8 air fuel so tune is spot on where i wanted it
What did your car trap again? I would think 60's would support 600whp fairly easily, and that should put you closer to 130-135 mph traps if 3500-3600 lbs raceweight
Car: check
Engine: check
Transmission: check
No doubt that you are out of fuel pump. The fuel pressure is dropping off. Here is a quick calc using 60#/hr injectors:
60 #/hr * 8 cyls = 480 #/hr total fuel flow at 100% DC.
Fuel weighs about 6#/gallon, so 480 / 6 = 80 gals/hr.
Convert to quarts, which is a tad less then a liter:
80 gals/hr * 4 = 320 quarts/hour.
Then google to convert to liters: 302 L/Hr.
So yes, no more fuel. Time for a double pumper. Also, that 255 lph rating is usually at 13.8 volts and 43.5 psi fuel pressure. As the pressure increases the flow drops off.
Instead of getting a gauge it is better to get a 0 - 100 psi pressure sensor and log it. Tough enough watching where one is going then have time to look at a gauge.
Injector DC% conversion (RPM & Injector PW based, this is for the common double fire set up):
6000 RPM / 60 = 100 RPS = 100 RPS
1/100 = .010 or 10 msec between injector firings
If the injector PW is 8 msec: 8 / 10 = .80, then * 100 = 80% DC
RBob.
RBob.
Single pump should support 550 whp. Maybe 500 in a higher bsfc boost motor. Depending on fuel pressure ofcourse. Your combo should be capable of maxing it out but i dont recall your traps being 500 whp level? Is the pump getting full voltage?
Car: 89 GTA
That's pretty much how I'm told how it works and seems to make sense since I'm maxed PBW at 6k or so and my AF/R starts to rise after that point. What don't make sense is the car is only trapping 114mph which is pretty low for maxing out the injectors though I'm reving it a lot higher now after this mini ram intake swap. I never did put on a fuel pressure gauge and drove around with it before I tore it apart, my guess is the 255lph is not supporting the mods. I have a walbro 400lph coming, hopefully I can make that fit if this is the problem...
Honestly the car should be trapping 125mph or higher with 12psi at 6k, something is up even though the wb02 is showing a nice AFR line up until that point. Plugs look fine too
No I haven't looked at the voltage at the pump, one of those need to do projects. I do have a hotwire kit from racetronics I could put in but I like to see how the stock wires hold up, it's been good to me up until this point.
Thanks Rob for the calculations, I run 44psi with the line off but I'm not sure how the boost affects the fp regulator. Looks like the pump change will have to be a go
Car: check
Engine: check
Transmission: check
At 44 psi line off and 12 psi of boost, the fuel pressure will (should) rise to 56 psi. It is a 1:1 ratio to maintain the same pressure differential across the injector. Which in turn has the injector staying at the same flow rate.
RBob.
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Sorry for the thread jack...
Car: check
Engine: check
Transmission: check
MLH100PGB06A
It has a male 1/8" NPT fitting and a 5V power supply (pick up from MAP or TPS). Use a 1/8" NPT to -4 adapter, then a piece of -4 Teflon lined hose to connect to pressure fitting.
For data logging I use the EBL products which makes it easy. Otherwise, I think the AutoProm has logging capabilities.
RBob.
thejimsterz28
09-15-2015 04:37 PM
