idle limiter AXXD
idle limiter AXXD
Getting my car running. 383 with 6 speed starting with a AXXD BIN. Ive read up on the idle limiter for the AUJP, does anybody know how to change this in the AXXD BIN? Changing the Idle Speed vs. Temp. has no effect. Wondering I this is limited too in AXXD. I have Tunerpro and Tunercat. Figured this would be a hex edit using Tunerpro. Any help appreciated.
This was an auto car converted to 6 speed. 92 Z/28 AUJP car originally.
Re: idle limiter AXXD
Any reason why changes to the table Target idle rpm vs. Coolant temp won't work?
I changed them all to 1000 and no change to the idle. Is there another table
I should look at? Can I just set it at the throttle blade so it won't go below 1000 rpm?
The problem with that is then the IAC won't have control, so I'm hesitant to do that.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
Being that the car was converted from auto to stick, make sure that the P/N input to the ECM is open. When grounded the ECM thinks the trans is in park or neutral.
RBob.
RBob.
UltRoadWarrior9
09-02-2015 08:24 PM
