AUJP $8D Idle Limiter - Code Question
Old 10-22-2012 | 01:14 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Need some help from the gurus who know the AUJP code or from someone with an ECM bench. Sorry for the long post, but some detail needed.
In summary, at idle in Park, my logs are consistently reporting ‘Desired Idle RPM’ values that differ from those set in the ‘Idle Engine Speed .vs. Temp’ table (table below):
Deg F---RPM
68-------950
90-------900
111------850
133------800
154------750
For example, a cold start-up log in Park at 80*F, shows ’Desired Idle RPM’ at 800 (and Actual RPM is approx. 800). Everything stays that way until 133*F is reached and then Desired and Actual RPM start gradually declining to 750 as per the table. But that’s not what the table says should happen. It says Actual start-up (and Desired) RPM at 80*F should be between 900 and 950 RPM and then decline from there, but they’re not doing that!
So on a lark, changed the ‘Idle Limiter’ values in the AUJP code at addresses 0x426C and 0x4270 from 40hex (800 RPM) to 50hex (1000 RPM) in accordance with this thread: https://www.thirdgen.org/forums/diy-...ter-730-a.html
Bingo -- Immediately upon startup at 80*F in Park, the log reported ‘Desired Idle Speed’ at 925, and car idles at 925. What??? According to the link and all my research, the addresses changed are supposed to affect in-gear idle only. My first thought was that the ECM didn’t know the car was in Park, but that’s not the case because idle increases by 100 RPM when going from gear to Park/Neutral, which is the value set in ‘Idle engine speed in P/N added to base’.
For the life of me with these results and observations, it looks like something in the AUJP code is restricting idle to 800 RPM regardless of whether in gear or P/N. But then that seems illogical because it would render the ‘Idle Engine Speed .vs. Temp’ table useless at cold temps where RPMs are set > 800.
Any thoughts or ideas on this anomaly? Could bin changes to not restrict idle to BLM cell 4, disabling AIR and CCP, or defeating EGR cause this?
Old 10-22-2012 | 01:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AUJP $8D Idle Limiter - Code Question
Your best bet is to check the P/N input status to the ECM. It is in the FMD status byte of the ALDL stream.
RBob.
Old 10-23-2012 | 10:26 AM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
RBob.
Makes sense, but how might I go about doing that? Have no clue what the FMD status byte is. I only see in a pin-out diagram that Pin D16 connects to the P/N switch, but the docs show 0 volts for both key on and engine running. Is that what I check, and if so, how check it since 0 volts? Resistance? Other? Thanks.
Old 10-23-2012 | 11:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can check the pin via an DVM, P/N is 0 volts. With a drive gear being close to IGN+ volts.
It is better to check the P/N status that the ECM has:
Code:
;  56      FMDBYTE1      BIT STATUS WORD
;          	0     PARK/NEUTRAL SWITCH (1 = DRIVE)
That is byte #56 of the data stream, bit 0 has the input status.
RBob.
Old 10-23-2012 | 03:26 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Code:
RBob.
Done. Thanks for the insight. Set up a Bitmask in the TPro .adx file (please see attachment):
In Gear? = bit zero of Diagnostic Data Stream byte 56 (byte 55 zero-based)
if False (0) = No (in P/N), if True (1) = Yes
If the bitmask is correct (would appreciate your review), the ECM is reporting the car is always in gear (bit 0 = 1). This is with key on, engine off, and also with engine running and does not change regardless of what gear the car is in (Park to 1st).
If the bitmask is incorrect, then I’ve got more work to do. But if correct, clearly the ECM doesn't know it's in P/N. So seems the next thing is to check Pin D16.
Don’t want to fry the ECM, so would the test be?
- Key on, engine off
- In a gear other than P/N to expect approx. 12v
- DVM +, to ECM Pin D16
- DVM –, to ground
Really appreciate the help!
Old 10-25-2012 | 07:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In an ADS file the index starts at the value 1. So it would be byte 56. I don't know if this was changed with ADX files.
Checking the input at the ECM is as you mention. Easy to use the ECM case as the ground point.
RBob.
Old 10-25-2012 | 11:33 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
RBob.
It must be because I have 55 (same setup as posted) and it indicates correctly.
Also, it may not update if the routine is in the "Engine running" section of the code.
Not sure on that, would need to test and see.
Jp
Old 10-25-2012 | 12:25 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Well, the Bitmask didn’t lie. ECM was not seeing P/N switch because the ECM pin at D16 had a broken retaining tang, apparently causing it to slide out when the 16-pin ECM connector was pushed in.
Thanks for all the help. And BTW, the bytes are zero-based in the TPro .adx file, for once the faulty pin at D16 was replaced; P/N was properly reported by the bitmask using byte #55 decimal.
Jp - P/N or in-gear is reported key on, engine off and engine running .
Azrael91966669
25
06-20-2017 04:04 AM
TRAXION
31
10-08-2008 01:00 AM
TRAXION
234
11-13-2006 03:55 PM
Z69
33
04-22-2006 03:26 AM
EdgesZ28
02-19-2005 07:01 PM
Quick Reply: AUJP $8D Idle Limiter - Code Question
