ARAP 6E Questions
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
ARAP 6E Questions
.......... In Flags and switches the first item is ..... Use Filter For Airflow ... it is checked in my bin ......... What is this for ? I'm running a single plane intake and solid roller cam ..........
.......... Second Q ... in tables ........ Rich / Lean Offset vs Coolant ........ my bin is set at 16 for temps 68-176 ... the rest are zeroed ...... At cruise my wide band reads 10-20% lean ... can I use this table to get closer to stoich ?
Car: check
Engine: check
Transmission: check
Re: ARAP 6E Questions
As for the "Rich / Lean Offset vs Coolant" table, it apparently only affects the fast O2 value. Which may, don't quote me on this, only affect when a cross-count occurs. Try changing some of the values and see what happens.
RBob.
Car: check
Engine: check
Transmission: check
This will have the ECM targeting a leaner AFR at those coolant temperatures where the value is greater then 0 (in the "Rich / Lean Offset vs Coolant" table).
If you wanted the ECM to target a richer AFR can change the three SUBA instructions to ADDA.
RBob.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I made these adjustable in both directions without code changes by adding 100 to all the values in the three table and then using the coolant table to subtract 100 from each value.
That way the changes to the coolant table can increase or decrease the O2 tables all at once.
Car: '87 Vette C4
Thinking about this it didn't make sense, so looked at the code again. The value from the above table is subtracted from all three O2 values, mean R/L, lower O2, and upper O2. Now that makes sense as it lowers all three the same.
RBob.
RBob.
