8D 730 ECM Closed Loop Disabled
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Did an "aww ****" I need some quick help with...
Using the S_AUJP.v3, TunerPro, Ostrich 2.0 to tune. Two years ago I put my car in storage and just recently fired it back up. Went on a drive today and discovered my last .bin I have is titled "CL Disabled" and sure as ****, it was stuck on 128. I can't find my notebook anywhere and had no luck with the "compare bin" feature to find what/where I set the chnages to keep BLM's locked on 128.
Two years ago I was on this board nearly every night and somewhat knowledgeable with tuning, just never thought I would have gotten this rusty!
I've looked over the fields I thought were suspect but no joy. So question is, what are the "common" changes to turn the learn mode off leaving it in Open Loop? My Wideband is occassionally showing an AFR of 16+ cruising around and I know that isn't good! Thanks!
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Re: 8D 730 ECM Closed Loop Disabled
Ha! I knew it was simple...Thanks man!
"Loop CLosed Enable Min Temp" was set to 151 deg C! Sure hope my eng temps never reach that! Ok, tuning again tomorrow!
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Thanks guys! Got it all working again! Had a blast today tuning in the WOT, about 5 good runs and it's relatively close to 12.5 AFR throughout the run. I feel really bad out there screaming down the roads to get the data, but that doesn't last long! Damn this IROC is quick and a blast to drive! Too bad I have to leave again in a month...
Thanks again for the help, certainly appreciate it!
83 Crossfire TA
09-08-2015 12:06 PM
