New to tunerpro rt
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
New to tunerpro rt
Hello, I am making my first attempts at data logging and tuning. After getting all the bins, ads, and xdf files in order i finally got the data logging to work! However, it seems every second there is a blip or "spike" in the data. I will attach the tunerpro playback file so you can see. It did not do this the first time but the second and every time thereafter i have this spike on the graphs.
I have the moates autoprom. 165 ecu, 305 tpi 5 spd, 3.27 gears. I have the akft bin in tunerpro but the akfx chip in the car (still trying to locate the downloadable version). the car runs pretty good but needs tuning due to new cam, head and exhaust changes.
here is my data log file. any help will be greatly appreciated!!!
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: New to tunerpro rt
Try adding a delay in the command macro as described here
http://forum.tunerpro.net/viewtopic....ighlight=delay
seems to solve that problem most of the time.
Engine: 305 tpi
Ok got it. delay worked. I used a spare ECM to run the emulation and worked really well. occasionally it would just disconnect and stop working but i think windows has something to do with it because it causes a blue screen of death when the auto prom is unplugged. windows 7 < OSX. Anyways, thanks for the help!
