Changes made by VE Master $8D ??
I'm wondering if the changes made by VE Master I'm seeing in the VE Tables are normal. I don't see any changes in the upper RPM VE table. See the screen shots below. I'm using DataMaster TTS to log with. I've set VE Master to correct the BLM's to 128, not the default 124. Each VE Master change is given a new .bin name, so the compare I'm showing in TunerPro should be showing the before / after VE Master changes.
Thanks,
dave w
Thanks,
dave w
Re: Changes made by VE Master $8D ??
I decided to use Microsoft Excel to recalulate the VE tables. The screen shots below show the results using Excel. I'm not sure what to think about VE Master?
dave w
dave w
Yup!
What it does
VEMaster is designed to improve the drivability of LT1-based GM vehicles that have been modified with a high-performance cam and/or cylinder heads. The program uses a log file created by the user driving the car under normal conditions. This log file must currently be made by using the commercial Datamaster software or the freely available Freescan. The program also requires a pcm image file created by Tunercat. LT1-Edit users can convert their .lt1 files to Tunercat .bin files using the TuneConv program.
How it does it
VEMaster parses the logged data file using only closed-loop, part-throttle data. The LT1 computer has 16 closed-loop fuel trim cells. Each of these cells contains 2 pairs of learns: a long-term left-and-right pair (a.k.a. BLM) and a short-term left-and-right pair (a.k.a. INT). For each VE cell in the VE tables, the program grabs the average BLM from the fuel trim cell the VE cell lies in, interpolating if necessary. The pcm bin file is modified, so be sure to make a backup copy before you run the program.
Recommendations for use
Since this program was designed to improve drivability and not top-end power, I recommend tuning no higher than the default setting of 3000 rpm. There are two reasons for this. One, any time you swap in a more radical cam for the stock cam, your VE will suffer at lower rpm's. However, at higher rpm's, the more radical cam will first equal, then exceed, the volumetric efficiency of the stock cam. At these higher rpm's, though, it is safe to assume one will be operating at W.O.T., and the fuel can more easily be controlled by adjusting the Power Enrichment table. Second, the fuel trim cells in stock form end at 2000 rpm. So from 2000 rpm on up, you only have that one set of learns. Presumably, most of the data (and driving) you will be doing will be closer to 2000 rpm than not. Therefore, the accumulated learns your car has in the 2000+ rpm cells will mostly be based upon data in the 2000-3000 rpm range, and thus should not be applied to higher rpms.
What it does
How it does it
I understand the information that is available for VE Master. I was thinking I would see the compare difference in the .bin files, making sure I renamed and saved each .bin file before and after VE Master processing. The compare differences did not show changes to 3000 RPM. I've been thinking maybe Win7 OS might be effecting VE Master?
dave w
dave w
I used one similar to this for LT1 $EE but I think it was written by Craig Moates. It worked in Windows 7.
But these are old programs, your excell spread sheets would be much better.
Anyway, the attached file is the Excel spreadsheet I put together.
dave w
codeysabatini
11-10-2015 04:07 PM
camaro1185
10-26-2015 06:51 AM
blackandblue02
09-10-2015 08:19 PM
Street Lethal
09-07-2015 01:09 PM
