383 Miniram 7730 PE/VE Tuning Issues
Car: 80 Corvette
Engine: 383 Miniram
Transmission: TH350c
Axle/Gears: 3.08
Hi Everyone,
I'm using saujp4 on 7730
Motor is 383/XFI 280/195/Miniram/30# Injectors
I've got my lower VE set, still working on upper.
I don't have my wide band installed yet
Was wondering if anyone with a similar combo would be willing to post or send their VE & PE Tables for comparison.
Thanks!
Thanks!
Car: 80 Corvette
Engine: 383 Miniram
Axle/Gears: 3.08
Re: 383 Miniram 7730 PE/VE Tuning Issues
Hope someone will chime in!!
How about any sites with roms posted ?
I didn't have much luck on moates
Car: 80 Corvette
Engine: 383 Miniram
Axle/Gears: 3.08
I'm shocked that no one has any info...
Its a 350, but still should be close if it's any help. Don't have my PE tables readily available, and I'm still getting them sorted out anyhow. I'd get you the exact numbers, but my laptop I use for tuning is on the fritz. Also, If its any help, I took a stock LT1 VE table, copied it, and manually entered it all into my VE table, then tweaked it from there.
Car: 80 Corvette
Engine: 383 Miniram
Axle/Gears: 3.08
I did basically the same, mine graph is much choppier lol.
Also sides are sloped a little more, i'll have to post a pic.
LT1Formula
20
11-14-2015 12:02 AM
