PCM's use of B2 Fuel Pump Signal
Car: '87 Camaro
Engine: 4.3L V6
I was wondering how the PCM used the fuel pump signal that it recieves from the B2 pin on a 7747. Does it just check to see that it is working (on/off), or does it use the voltage to correct fuelling?
I ask because I had added a fuel pump relay to the rear of the car when I moved the battery to the trunk, so now the PCM only sees the relay's voltage, not the pump's. I just need to know if I should run a wire back so the PCM gets the reference voltage it may or may not need.
Thanks in advance.
Thanks in advance.
Car: check
Engine: check
Transmission: check
Re: PCM's use of B2 Fuel Pump Signal
It is used for the fuel pump relay malfunction diagnostic routine and for the voltage compensation of the injector PW.
RBob.
RBob.
Car: '87 Camaro
Engine: 4.3L V6
Thank you. That's just what I was looking for. I just wanted to make sure of this before I took the time run the wire.
NBrehm
08-25-2015 11:49 PM
