AXXB vs ARZU and Other questions..?
Car: 1991 Pontiac Trans Am
Engine: 305 TPI 5.0L
Anyone know the difference between AXXB and ARZU? The only difference I can see form the Gearhead-efi BCC decoder is tire size. Can I use either of these with a 7730 in a stock 305 TPI setup?
I want to replace my MEMCAL because I opened up my ECM and found some weird MEMCAL in there that's for a 350 corvette. I'm also replacing my refurbished Delphi 16198262 for a stock 7730 because the refurbished ECM has been acting up. I just want to put everything back to stock...Any ideas?
Car: 1990 GTA
Re: AXXB vs ARZU and Other questions..?
If you have both bins just do a compare in TP but if the car is stock just go with the original bin, otherwise I would just start with a S_AUJP bin.
The bcc differences are going to be minor to cut emissions. The axxb is available from amazon.
http://www.amazon.com/gp/offer-listi...&condition=new
Car: check
Engine: check
Transmission: check
Odds are the ARZU calibration has the vehicle speed limit set to 254 MPH. While the AXXB calibration has it set to 120 MPH (+- 10).
RBob.
Thanks for the info. From what you are all saying it looks like the differences are miniscule and I can use either PROM in the 7730 with stock 305 TPI with no problems.
my82roc
03-17-2010 07:49 PM
