Rear change will require changes to ECM
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
OK, sorry if this is in the wrong forum bit it seems logical to me to start here, so please don't flame me if I am wrong.
I have been doing some work on my '88 IROC drivetrain and ECM/Memcal that I have in my '87 el camino, so I have gotten somewhat profecient in making the changes and burning chips.
I have the Tunercat and $32b def file, for this would like to not have to spend too much more $$$.
I have a '90 IROC convertible and the 2.73 rear (drum brakes) has some issues, mostly bearing noises. I have an '89 3.23 disc brake rear and am considering installing it in my car. The mechanicals are one thing, but to make changes to the ECM so that the lockup on the torq converter is where I would like some advice.
If I go this route to change out the rear, what ECM should be on my '90 and does it use the MEMCAL type setup like I have in the '88?
The motor (LB9) is pure stock and I was wondering if I just could get a stock chip for the setup, even though they never made that setup ('90 LB9, auto trans, with 3.23 rear). Seems to be the easiest but not sure what chip code I would be looking for? Otherwise then I have to look into modifying the chip that is in the ECM, which is more work.
I would really like to swap out the 2.73 drum rear to the 3.23 disc brake rear, but this might be just too much work with little return.
Opinions and feedback please!
Bruce
Bruce
Car: check
Engine: check
Transmission: check
Re: Rear change will require changes to ECM
Need to change the speedometer gears in the transmission. This way both the speedometer and ECM have the proper MPH showing. See the transmission board sticky's here on TGO. There is one for 700R4 speedometer gears.
Once the 3.23 rear is in, you can make changes to the TCC lockup points. But this is mostly a user drive-ability preference.
Of course, if you don't care if the speedometer is correct, there is a VSS PPM value for the magnetic input in the ECM's calibration. Can tweak this until the ECM has the correct MPH.
RBob.
RBob.
Here is a link that may help you can use there calculator chart to pick the correct drive and driven gears.
http://www.transmissioncenter.net/sp...n_______va.htm
Engine: 305 TPI LB9
Thanks for this feedback. I was including the speedo gear in with the "mechanical" portion.
Any idea if the ECM on my '90 is a 7165? Assumming so, then it has the same type MEMCAL, thus the physical portion of this would be the same?
Then next question is what is the definition file, $32b??
Any ideas?
Any ideas?
Engine: 305 TPI LB9
Any idea if they made a stock chip for my LB9 motor with the 3.23 rear?
Car: check
Engine: check
Transmission: check
RBob.
Engine: 305 TPI LB9
Engine: 305 TPI LB9
Engine: 305 TPI LB9
hectre13
12-11-2023 08:14 AM
