2 Ques. 1 on Tunerpro RT
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I am about to dive in head first. I am very close to buying a APU1 Autoprom, and get after it. I have two questions i would like answered first before spending $350.
1. When i buy the Autoprom, will it be able to read the tune thats already on my car. From what i understand from the previous owner that it was tuned for the setup it has, cam, runners, heads, etc. Since then ive upgraded/replaced to 24lb injectors and its cause a idle problem. I wanted to start with the tune done my whoever because before it ran the car great and dont want to mess up by having to start with a stock tune because i have no idea what kinda cam the car has.
2. Ive been playing around in Tunerpro RT before i buy the autoprom, but i cant find the Fuel Injector Constant Flow parameter. Anybody know what its called?
Car: 1989 IROC
Re: 2 Ques. 1 on Tunerpro RT
I figured as much by reading on moates, it's just that they say it will let u read the stock tune and my tune is not stock. Also as far as my second question, I'm using the stock files for my car off the tuner pro website. So you are saying that my tune may or may not have a injector flow constant?
Moates says the stock tune, for peopl just getting into tuning to know they can read their EPROM. Stock or modified binary, reading it is the same.
That is correct, there may or may not be a specific injector flow constant. Some codes use a table for a base scaler, usualy modified by EGR percentage.
Car: 1989 IROC
Ok ty but for one more ques. If my tune doesnt have the constant value. Will i have to modify the whole fuel table to compensate for the 2lb extra.
Car: 1989 IROC
I'm using the $6e.xdf off of tunerpro's website. I haven't downloaded the one from my ecu yet cuz I don't have the hardware yet.
1 Post
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Single fire FI size @40psig
Double fire FI size @40psig
Set both values to your injector size.
Car: check
Engine: check
Transmission: check
And the "@ 40 psig", is really "@ 43.5 psig", assuming you are running stock fuel pressure.
RBob.
So, if by increasing the injectors from, say, 19 to 22 for example, this table "Injector pulse width correction vs batt voltage" will require an increase or a decrease in the "usec added" column? And I'm assuming it should be adjusted in between 10 and 15 VDC (I don't see the voltage going below or above that range), correct me if i'm wrong though..
Car: check
Engine: check
Transmission: check
RBob.
Car: check
Engine: check
Transmission: check
RBob.
